Corners are rounded but previewing as sharp
Please help - I’m cutting out letters and some do not have sharp corners. Why are angles not coming out sharp? The Vectrics Software previews them as sharp, but when it cuts it has a bubble/curved edge. I’m using a 12 degree v-bit on Shapeko CNC machine.
MAC Letters
Is the definition of the tool correct in Vectric?
Does the tool cut well with minimal runout?
Hi Will, The bit is programmed correctly since I’ve yet to have this issue. I tested a triangle with the same angle, and it did not have as severe as a problem.
Check the geometry?
Try cutting the geometry in Carbide Create and compare?
