I bit off a big chunk to chew with this project. As you can see in the attached I have a hexagon cut from Poly. I cut the numbers on the back. It will be a “Coffee Table” game.
Would like some input from the group on how to color the numbers in a timely fashion. Right now I use a permanent marker, then rub with a rag that has WD40 in it to remove the excess.
I have 200 hexagons with 6 numbers on each. Yes, I thought of spray-painting the surface before the numbers are cut. But my quality control manager (wife) does not like that idea.
