I have created inset stars (shape of US flag stars) on my project using a vee carve. Now I want to cut another piece of wood that is the complete inverse so that they will insert into the previously cut stars. I tried using the same vee carve bit (90 degree) with a tool path of “outside”, but it is not even close. The points are all rounded.
Has anybody else done this? If so, please tell me how you did it.
That’s because you have the path offset from the star.
You need a Contour | No Offset path which cuts from the surface to the bottom of the stock — Carbide Create can’t preview it, but it will cut with the tip of the endmill at the tip of the star which will be as sharp as yours is drawn.
