Can I create an svg file from a project I made in carbide create to use on a different machine?
Yes, File | Export SVG…
Oh lord i just saw it. Thank you!
Are you using CC V6 or V7? The SVGs from V6 might not import into other programs, V7 is fine.
A 10 inch square exported from CC V7 (743) imports to VCarve Pro 11.5 as 10.66667 inches square. Always enclose your work in a reference box that you can use to restore the desired size.
Good to know. Thank you!!
I am still in 6. I’ll check for the update
