Erring on the side of caution and am not finding anything solid online or on “white side” website. When I select this tool it’s scrambled code. Does someone know where to find speeds and feeds for CNC spoilboard 1” 1/4 shank #6210
2D f/s
Plungerate
Feedrate
RPM
Depth??
I have the same fly bit and sent an email to Whiteside and they replied;
15,000 RPM at 100 ipm is a good starting point.
Here is what I entered in my custom tool data base:
whiteside, 6210
#601
Geometry
Diameter:
1.000 in
Flute Length:
0.125 in
Included Angle:
2.0
Num Flutes:
3
2D Cutting Parameters
Feed Rate:
80.0 in/min
Cut Depth:
0.010 in
RPM:
16000
3D Cutting Parameters
Feed Rate:
80.0 in/min
Stepover:
20.0 %
RPM:
16000
Finish Allowance:
1.000 in
Here are the fields from the CSV file;
| number | vendor | model | URL | name | type | diameter | cornerradius | flutelength | shaftdiameter | angle | numflutes | stickout | coating | metric | notes | machine | material | plungerate | feedrate | rpm | depth | cutpower | finishallowance | 3dstepover | 3dfeedrate | 3drpm |
| 601 | whiteside | 6210 | Fly Cutter | end | 1 | 0.125 | 0.125 | 0 | 2 | 3 | 0.125 | 0 | 10 | 80 | 16000 | 0.01 | 1 | 20 | 80 | 16000 |
I really appreciate the response and information. Thanks!!!
