Creating 3d images
As noted that vector version of the SAC shield should cut well as a V carving:
It doesn’t lend itself to cutting different elements at different depths because a single piece of geometry:
will describe the outlines of multiple elements of the design
You would want a colour version:
if only it were drawn so that each element when selected would have an outline which would describe only the visual area of it — which is not the case:
For a bit on fixing this sort of thing see:
cdnlogo.com_strategic-air-command
Basically, you’ll need to duplicate all of the overlapping elements and use either Trim Vectors, or Boolean Subtraction to arrive at geometry which describes only the visual portion of each element in a way amenable to how you wish to cut the design.
