Creating a 3D terrain carving from an STL
…as requested on support…
Given an STL:
we import it into Carbide Create…
which is rather shallow compared to the original 3D model:
If we instead model the design at the original size/proportion:
(and also set the Model Resolution to Very High)
which gives the size in comparison to the original of:
and if we import into this we get:
which if we apply 3D toolpaths we get:
Next, we look at scaling the design up…
48 inches is 1219.2mm, which if we divide in the long dimension, 108.42mm we get a scaling factor of: 11.2451577
Multiplying that by the height of 9.89 we get: 111.21461mm — converting that to Imperial for familiarity we get: 4.37852795 inches.
Rounding that off to 4.375 inches, we set up the file for these dimensions:
so we draw in geometry and import:
which we can then apply 3D toolpaths to:
which then previews as:
If we then export this as a PNG:
We can then reimport with a more modest height, but still preserve much of that height difference:
insofar as 1" of thickness allows:
which when cut w/ the 3D toolpaths previews as:
