stock size is 6 7/8 inches wide X 7.00 inches high and .94 inches thick. I was thinking about a hexagon patter with a 1/2" border or maybe 3/8" border.
since the shape and design are wider than they are tall, it is arguably better to rotate either the stock, or the geometry by 90 degrees — this is most easily done by rotating the stock:
Since we won’t want to worry about exactly lining up the stock, we’ll want a bit of space around the outline to the sides which is easily done by aligning to the center of the stock:
It will be impossible to cut the sharp internal corners, unless we use an Advanced V carving, and such would just collect dust, so we inset by the radius of a ball-nosed tool (we will use a #202):
There are two ways to approach the balance of the design — things can be cut in 2.5D, using appropriate toolpaths, or fully modeled in 3D — first, 3D — this will require the stock:
