as requested on support…
Given a photograph:
we launch Carbide Create:
and use Trace Image:
adjusting the Threshold Slider until we arrive at a reasonable result:
Trace Image:
Ok
Increase the stock size a bit, or slightly reduce the design and then center things:
Scale
Done
Align Vectors
Center the selection on the Stock:
Draw in a surrounding rectangle:
Select everything:
and do an Advanced V carving:
using the Current Selection:
Naturally, better results could be achieved with a higher resolution, better contrasting photo, or by re-drawing the entire photograph.
