Set up cribbage board layout. In toolpath screen shows random hole on board (and does get drilled); does not show up in design screen and cannot remove. How can I remove this phantom hole?
Edit the toolpath and select the current geometry, then go back to the Design tab and verify that only the desired holes are selected — if you have trouble doing this, upload the file and we’ll look into it with you.
Also, it might not be a hole. The drill toolpath seems to work on any vector, including the outside perimeter rectangle…
If you’re not using layers, try the Edit → Select… → Select Circles command
Problem solved! Always can count on the Community Forum for answers. Appreciate the helpful hints.
