@krgbcg
Looks very solid, thanks for posting Richard.
What was your technique for the paint and finish?
I sprayed 2 coats of sanding sealer on the wood BEFORE routing. Once completed, I sprayed with spray INK, let it dry then sanded off. (I tried paint with no sanding sealer first and it bleed deep into the wood to the point I could not sand it out.) The finish is 2 coats of Tung Oil with 0000 steel wool buffing in between coats.
