Hi all just Need a little guidance I need to cut 23mm deep slots at 6mm wide,the 102 appears to be far too short,can I get a longer cutter??If so where would I source one from.?
Some suggestions at:
I’ve used the Garr Tools long reach endmills:
https://www.garrtool.com/product-details/?EDP=41030
very successfully and can recommend them wholeheartedly.
Thanks Will,they are what I need,tracked down the local agent here and do not have any in stock and not planning on ordering for a few mths so may have to try another Avenue,Amana do not appear to have them,would you know anyone else who may supply.Thanks
Hi @Graham,
Sometimes just resorting to Amazon-quality endmills works, have you tried searching for “1/8” long reach endmills" ? And then look for the ones with a minimum cutting length of 1"
I’m sure there will a plethora of suppliers in the US, similar to Rennie in the UK?
I’ve just ordered two of these with 62mm flutes.
They’ll probably ship to the US, if not.
Good word, plethora. I first heard it in context, in the film (movie) The Three Amigos.
Hi Peter,The issue I have is I am in NZ,have tried every possible source locally,can get 4 mm but do not have a collets to fit.I am now resigned to the fact I get some from US or UK,shipment is quick
