I’m about the carve a piece that is well over 50mm in height. I don’t need it to cut to the base of the stock just the surface. Is there any major issue with me cutting a hole in the waste board and mounting the shapeoko on wedges to lift it up, to allow the clearance required?
I appreciate you need to keep the baseboard as rigid as possible but we are only talking a 250x250mm hole. I could, of course, replace the waste board afterwards?
Folks have done this, and it works well — at least one person who have really liked working thus have replaced their wasteboard with a threaded metal one with integrated vise.
I cut a hole out of the MDF waste board. Then added straight brackets on the underside to allow me to fix the hole back. So now I can quickly open the hole and lift the height with wedges when required.
Mine will be a XL or XXL with Z+ and CCR or Makita router. Knowing that figure would help in designing the table/enclosure, and/or in deciding to cut a hole in the base wasteboard before assembly.
