I am new at CNC and Nomad 883, I have cut a few things out of wood and plastics. I have tried to cut aluminum (5052) with the Nomad but no matter how slowly I plunge the 102 bit, it crabs the metal and stops. I think the RPM is max., the cutter is new. I am just trying to cut .125 inch holes.
I have tried all ways to cut aluminum but the motor stalls no madder what I do. I just watched a video that
Carbide 3d made of a Nomad 883 cutting 6061 aluminum, 1/8" thick using the following:
.125 " , 3 flute end mill, feed rate: 6 IPM, plunge rate: 5 IPM, RPM 8000, .02 " cutting depth, with synthetic none oil coolant
You should have the file that was use to make the video, would you send it to me and I will set my machine exactly as stated in the video and try to make cuts in 6961 , 1/8" aluminum. If it works, I am doing some thing wrong
Can someone recommend a good website or calculator for identifying the recommended feed and speed for specific materials? I have looked at a few websites, but I get the impression the rates are for larger CNC machines.
G-wizard’s pretty good, and goes on sale fairly frequently. If you buy a one year “subscription” you’re set for life for a nomad. Sometimes he has special deals to get a discount on a carbide machine if you buy gwizard at the same time. Check out his site.
