I am going to try and show everyone what goes into this piece. So I downloaded a deer/elk stl and brought it into F360. After having much issues in the conversion process, it is easier to simplify the object before bringing into F360. Please save yourself 6 hours here. Microsoft will help. After you have a good mesh, use memento to export to a quad stl format. Fusion can handle these better. The idea here is to create a cutting board with a positive effect. Ie to extrude the object and then mill out the remaining to flat.
Before we can start I milled using the SO3 one piece of sycamore flat. Milled one side, flipped and repeated. <src="/uploads/default/original/2X/2/2a03f6bec4c1d73d1ccf586d3c4c27d2140b09c5.jpg" width=“375” height=“500”>
