I would like to create a chopping board and I have attached a .jpeg file of what the entire thing should look like. You will note at the bottom, center a heart and a cross that are intertwined. What I want to do with this is create an inlay. Also attached is the .svg file from which come the cross and heart. The actual size of the cross/heart in the layout is X= 2.6265, Y= 3.25. So, here is what I am looking for some help with: 1) What size V bit would you recommend I cut this with. I presume a 60 degree would be too big. I do have a 30 and 15 degree I could use, and 2) what should be my cutting start depth and cut depth be for the male and female sides be? If I were using a 60 degree bit I would use a start depth of 0.0 and cut depth of .011 for the female and a start depth of .09 and cut depth of .02 for the male. Any suggestions?
Thanks
