I have everything set up to cut in a specific order (CC), but it does its own thing. Why?
What did I do wrong?
Sometimes the toolpaths change order — I believe this is fixed in CC5 — please post the .c2d file and generated G-Code and we’ll do our best to look into this with you.
Try the beta?
The tabs in the beta version is not working right.
Will,
Since the tabs aren’t working in the beta version, I need to go back to the previous version of CC.
How? I already replaced the app with the beta.
The beta is supposed to install in a different location using a different filename. Using the default install it won’t overwrite the previous version.
We have the previous version at:
https://carbide3d.com/carbidecreate/download/
What do you mean by
