I’m trying to cut a 60 inch eagle wing (Garage Eagle) from a 1x12. My machine will cut 32 inches. I’m using carbide create pro and have an svg for this but I haven’t been able to figure out how to contour cut the wing.
It will be a garage eagle there something else I’m missing? is there away to cut this out?
neilferreri
(Neil Ferreri Ω)
October 16, 2021, 2:44am
2
You’re looking for information on “tiling”. Lots of ways to do it.
Here’s some info to get you started
https://wiki.shapeoko.com/index.php/Fabrication_Techniques_%26_Hardware#Tiling
Also, check out the current contest… You should read the entries and enter yourself!
Time for a new community challenge!
Make something that is larger than the work area of your machine!
I’ll use one of @MarkDGaal ’s pics of a tiling setup as an illustration (hope you don’t mind Mark, I just like that picture)
[image]
But you could also make something that is assembled from parts that each individually fit in the machine work area (I’m looking at you, Nomad owners!)
Rules for this 25th challenge:
submit your entry in this thread (you can post multiple entries if you want)
y…
Also, what’s a Garage Eagle?
If I pasted right. Garage eagle is like this. This one is different than mine
I can’t find image of mine. It’s put together like 3d. It has six parts to cut out. The wings are the longest at 60 inches
system
(system)
Closed
November 15, 2021, 1:40pm
5
