I’m making a small storage block for my bits, which entails making loads of holes in a piece of wood. When I run the job, the Nomad cuts a little bit out of each hole, backs out, and moves to the next one. This is not only wildly inefficient, it’s also incredibly annoying to watch.
I see the setting to “link by depth” in MeshCAM for the waterline pass, but these holes are too large to just waterline. How do I make it also link by depth in the roughing stage?
@MrHume, there is no “link by depth” in roughing. The best you can do is make the holes in batches, using Set Machine Region to select one or a few adjacent at a time.
How big are your storage block holes? If not more than 3/8" in diameter, you could use MeshCAM’s drilling routine to drill the center of the holes using a 1/8" diameter bit or endmill held in the collet, followed by the waterline+pencil 2D finishing pass to finish the holes to size.
Frankly for an array of holes I’ll draw them in 2D and use SheetCam to machine them as pockets. I’ve been using SheetCam 2.5D-specific CAM as long as I’ve been using MeshCAM 3D CAM. Horses for courses. Robert developed MeshCAM to machine 3D workpieces, and I view its 2.5D capabilities are a “bonus functionality” which became evident over the years (The “breakthrough thread” is http://grzforum.com/viewtopic.php?f=3&t=711&p=1454 )
@WillAdams Thanks for this. Unfortunately I have a Mac so I can’t run the program you linked to, and I don’t know how to compile C++ so I can’t make a version for my machine (although I suppose I could try to learn to compile C++ programs, hm…). Glad to know there are optimizers out there. Honestly that hadn’t occurred to me, though it seems obvious in hindsight.
@Randy I’ll look into SheetCAM and see if I can figure it out. They offer a free trial, so I’ll take a whack at it.
EDIT: actually it turns out SheetCAM is not available for Mac. Oh well!
Mac users can run VMWare Fusion (or Parallels) - virtual machine software that allows multiple operating systems to run concurrently with MacOS. The packages themselves are too expensive however since they create a virtual machine one must have a Windows license key to install Windows within; Linux can be installed for free.
Windows in a virtual machine can run must, but not all, CNC related tools. I run high end CAD/CAM packages and tools I cannot find Mac native this way.
