Cutting out detailed parts
as requested on support…
I am curving on red Oak wood, I need to use 1/16 bit for small details, but all my 1/16 bits broke only while using them on Red Oak.
where the file is:
and we need to re-work it to allow it to be cut out…
The first consideration is toolpath ordering — cuts should be ordered from top → bottom, and inside → out.
So the cut for the board to a depth:
Should be the first cut made, so it gets moved to the top of the list, another consideration is that it is being made with a #102 DEFAULT — better to select a tool and feeds and speeds suited to this cut/material — checking the radius:
a #102 is correct, but we are cutting hardwood so:
(and the cut time goes down to 6 mins. from 14)
For more on selecting tools/tradeoffs see:
and
One toolpath makes decorative cuts:
and may be left as-is (but moved up to be cut before any sort of outside cut).
The balance of the cuts are all cutting parts out and may be treated as a unit.
Thank you William for your help. I will follow your instructions.
One concern is that the parts are so closely packed that in some places even the very small tool originally specified is not fitting:
So we separate things using the Pro feature Nest Vectors:
setting the spacing an options to match the 6.35mm diameter tool which we want to use to cut things out:
and we wait for the nesting to complete:
but in doing so, we become aware of an unnoticed aspect of this file:
which arguably needs to be addressed (necessarily so, since the Nesting seems unlikely to finish)…
Begin by making a new layer:
then select the elements which are associated with toolpaths:
using “Select current vectors”
and move them to that layer
Then hide that layer and check each remaining bit of geometry:
Some of which is quite mystifying — where it isn’t obvious what it is to be used for, we move it to a temporary layer:
Continue the investigation, drag-selecting and moving one instance of each outline to a new layer:
and again, where elements are puzzling:
moving them to temporary.
Once everything is moved out of the way:
Nothing seems to be left, but selecting all:
reveals 8,785 vectors:
with a size of 0,0
delete
With a more workable 62 vectors, we re-try the Nesting.
which then succeeds, but scatters what should have been internal elements:
Instead we offset a small distance:
Apply
Move that to yet another layer
Deselect all of the outlines:
and delete
Then clean up where necessary:
and try again
eventually, one would arrive at something along the lines of:
which would allow one to select all the geometry on the outlines layer, offset it by 7mm
and use it to cut as a pocket.
Group Vectors
then add the outlines for cutting geometry:
and cut as a pocket down to tab height:
we then duplicate that toolpath and edit it to be a REST machining toolpath which cuts all the way through with the smaller tool:
which previews as:
We then remove the offset geometry from the selection:
and assign an Outside Contour toolpath to finish the cut, respecting the tabs:
William, I have a question please, which bits and settings you used for the first two toolpaths, “Engraving details” and “Board depth”.
where you said: and cut as a pocket down to tab height” , and where you said: “We then remove the offset geometry from the selection”
In both, the list on the left shows:
  • Engraving details – 4 minutes
  • board depth – 6 minutes
  • Pocket Toolpath 2 – 33 minutes
  • Pocket Toolpath 2 – 40 minutes
I left those two toolpaths unchanged (aside from moving the geometry to a new layer).
My skill set is far below Williams but one simple trick that I have used with projects similar to this is to just use a thicker board than I need for my final pieces. I then cut out all the pieces but not completely through the board which eliminates the need for tabs or the instability of each individual piece. Then I just resaw the back side of the entire board to my final desired thickness on my bandsaw and each individual piece simply falls off onto the bandsaw table. I then just do a little sanding on the backside but have no need to sand for tabs.
I’ve done a variation of this. Cut on the bandsaw to leave an onion skin, then use a drum sander to remove the skin. The parts are consistent in thickness and are sanded after coming off the drum sander.
Thank you so much William, I am grateful for all the hardworking you put for us.
This community is a blessing to all of us.
thank you for all community members and Carbide Create team.
