I have been asked to make a sign and was given a file of what this sign should look like. The request is to have the pieces cut out and glued to another board.
The issue im having is when i import the picture there are double lines and that ‘thickness’ makes the pieces very small almost not existant at the project size of 16" wide. I can manipulate it to be better by adjusting the ‘offset direction’, however its still poor.
Is there a way to import the file without tracing it so that i get ‘one’ line and not ‘two’ if that makes sence.
The flower and leaves are most of the issue i have.
Thanks for your time
If need be, ungroup:
Then go into Node Edit mode:
Zoom in:
right-click:
Choose “Cut Vector”
Repeat for the other side:
Repeat on the other side of the geometry:
Zoom out and select the geometry which is not wanted:
Make a new layer to store the geometry on:
Hide the layer:
Zoom in, clean things up, Draw in geometry to close things up:
Select things and use “Join Vectors”:
Attached as a v7 file.
Raelynn_v7.c2d (192 KB)
Incredible!
That was beyond kind!
Ill take some good time to learn what youve sent me.
