I am working with black walnut pieces 1” wide and will be using a dado to join them. What clearance should I use for a good fit. A little over 1” I assume but not sure how much.
Thanks in advance
Steve
Thanks in advance
Steve
For a good, snug, “slip fit” I use about 0.010" (0.25mm) for most wood. Adjust for discrepancies in nominal -vs- actual size. If you’re gluing them you can probably go up to 0.015".
Thank you for your quick reply. This will be my first project!
