WillAdams
(William Adams (Carbide 3D))
November 2, 2024, 2:18am
1
As requested on support…
Given a design:
where one wants decorative V cuts along all the geometry, one would start by selecting all the interior elements:
and assigning a No Offset Contour toolpath to the desired depth:
which previews as:
For the outline:
It would be best to close this geometry using “Join Vectors”
or, just re-draw it:
Boolean Union:
OK
Since the tool is 90 degrees, the added depth/offset are the same so offset to:
Apply:
Apply a No Offset Contour to the greater depth:
which previews as:
For cutting out the design it will be necessary to use a #201 since the stock thickness (0.75") is greater than the flute length of a #102 — best practice is to offset by tool diameter plus 10%:
Apply
Select the offset and original geometry:
and assign a Pocket toolpath to tab height or the penultimate pass:
Then add tabs to the original geometry:
Assign an outside Contour toolpath which starts at the bottom of the preceding pocket and finishes the cut:
It will be necessary to use a chisel or file to clean up the corners.
Thanks, William.
I certainly wasn’t expecting all you did.
Bueno and gracias for the tutorial.
DJC
WillAdams
November 2, 2024, 1:26pm
3
My pleasure! It’s what we do here.
Alternately, you can lean into the rounding:
Draw a rectangle the size of the rounding:
and use the Centerpoint to position it:
and one corner to draw a circle for the rounding:
Then use Trim Vectors and Node Editing to combine things:
OK
Node Edit:
Cut Vector
Select the excess vectors:
d to delete
Done
Select the two geometries:
Join Vectors:
Yes
Repeat at the other intersections, then edit or re-draw the central geometry:
WillAdams
November 2, 2024, 3:43pm
4
Or, better still, use the Corner tool which is intended for such usages:
Just adjust the radius to what is desired and click on the ones which need rounding.
(It will still be necessary to adjust the interior geometry)
system
(system)
Closed
December 2, 2024, 3:43pm
5
