Problem did not occur until i turned on Tiling. Once tiling is turned on, the steps above will create the issue. Here’s the file I’m using: File with tab issues.c2d (356 KB)
and my steps:
Open the file
Select the middle rect
Add three tabs (I put mine on the top of the rectangle - out of the lower tile - but I’m not sure if that matters yet)
Click OK - the tabs will remain. All looks good
Now go to Toolpaths and click Tiling on
Now go back to DESIGN, and click Tabs and press OK.
The tabs will disappear.
EDIT: @WillAdams Have you reproduced it yet?
I checked…it does not matter if the tabs are in or out of the 1st tile…and it doesn’t seem to matter where you place them. I’ll do a little more experimentation and see if I can localize the issue even more.
ANOTHER EDIT
I created it from a file from scratch.
Created a 36" Rectangle
Applied tabs and pressed OK - everything worked correctly
Went to Toolpaths and selected TILING
Went back to Design and clicked TABS and OK - and the Tabs disappeared and cannot be created again.
@WillAdams I rebooted (as requested) and started from scratch with a simple rectangle on a new design - and was able to reproduce the problem with these steps:
Design Tab
New Design
Draw a rectangle
Apply Tabs (Click OK - Tabs Remain)
Toolpath Tab
Click Tiling On
Design Tab (Rectangle still selected)
Bring up Tab Dialog
Press OK (Tabs Disappear)
Please let me know if you are able to reproduce this behavior.
I have a work around until this issue is fixed. Once you create the tabs and they disappear go to edit menu and undo. Tabs will reappear.
Hope this helps
Now that’s a sweet work-around! It turns out that the undo will even preserve a new tab that’s added (or a change to the existing tabs). Excellent. I guess they’re doing something after the edit is completed to eliminate them. Good catch. Thanks!
