I tested right on the spoil board and I looks like it starts deeper and gets less deep as it moves right. Any idea what might cause this?
A mm is alot for me.
Usually it is a tram issue. Have you flattened your spoilboard and checked tram? What type of machine do you have?
If an SO5 check your square.
If an SO4/SO4 Pro check your v-wheels
If an SO3 check your v-wheels
On all 3 models flatten your spoilboard and then check tram. If tram is off you will need to fix that and then resurface the spoilboard.
