Worked up a design for this in BlockSCAD:
including an option to lay out the parts to cut:
and
By golly, I think you’ve got this figured out, Will. +1
Thanks!
If anyone wants to experiment with it:
https://www.blockscad3d.com/community/projects/988304
Naturally the next step is exporting to OpenSCAD, moving the variables and adjusting them for the Customizer and adding projection() commands where necessary:
then export SVGs and import into Carbide Create.
Cutting this went well:
Just needed a few cuts with a utility knife to free it, and a few swipes with a file to clean up the edges.
Should have been a bit more patient about assembly (and taken the time to use painter’s tape in addition to rubber bands for clamping):
Next up is sanding and finishing and hardware.
File for cutting at: Design into 3D_ Box_ Miter_CC509.c2d (116.8 KB)
(Note that it needs CC5xx)
