Detailed V Carve Problem
I’m having a bit of an issue with getting either Fusion 360 or CarbideCreate to V - carve some very fine lines of a logo.
Logo looks like this:
I’m trying to V-carve all of the detailed/inner features on the olive leaves and waiter’s hands and serving tray… but both F360 and Carbide Create only recognize a small % of the line segments…
Fusion File:
I’ve tired identifying the diameter of the tool tip as 0 as well as playing around with tolerance and angles… but I just can’t get F360 to try and do the other line segments in the sketch… any ideas?
Simulations from F360 and Carbide Create
Screen Shot 2022-02-08 at 4.43.16 PM
It doesn’t work in Carbide Create? What angle V endmill are you using? Have you tried a 30 degree w/ Advanced V carving?
It generates identical tool paths in both softwares, only going after a portion of the contours selected. Yes, I’m using a 30 Degree Amana bit in both softwares.
see the simulations… they are the same.
Post the file here, or send it in to support@carbide3d.com and we’ll look into this w/ you.
The Fusion File is linked above. Hold on I’ll recreate the Carbide Create file now.
CC file:
QuattroLogo_CC.c2d (1.2 MB)
The design is for the most part made up of open (unclosed) paths (indicated by being magenta):
Normal V carving toolpaths only work w/ closed paths.
There is a new feature which allows using a V endmill w/ open paths:
@WillAdams do you have a V bit selected for the above? my simulation looks like this with a V-bit.
EDIT… the simulation looks that that when using the Amana 45771-K “engraver” but looks normal using the #302 Vee bit.
Seems normal in Carbide Create:
using the #45771-K defined as a V endmill:
The alternative would be to open the file in a vector editor and instantiate the strokes, then union them and do a normal V-carving.
I got her done. Thanks @WillAdams
