Dewalt 611 Bearing Rebuild
Been troubleshooting some cut issues for a while, after fixing and eliminating a lot of other problems (loose v-wheels, stretched belts) finally got down to bearing play on the router. I didn’t measure it, but could grab the collet and feel the physical movement up and down. I’d guess at around 0.005 - 0.008" range based on the cuts I was was seeing, which really showed up in aluminum. So, time for a rebuild!
I looked around and could not find comprehensive instructions on what’s needed and how to get everything apart. Wanted to document that here so anyone trying to do the same knows what you need before you get started. The parts are cheap, order a couple sets to have on hand and you can rebuild this thing in about 30 minutes. (I made the mistake of only having the bearings, here’s everything)
Parts
If you’re lucky enough to have a Dewalt service center nearby (which I do here in Dallas), you can pick parts up for free and the prices are surprisingly low. Another site, MM Tool Parts, also carries all the parts.
Dewalt Toolservicenet
MM Tool Parts
Diagram Description Part # Cost (11/2022) Needed Note
50 Insert A26125 $1.96 1
52 Nut L.H. A25250 $1.19 1
53 Upper Bearing N110359 $2.06 1
51 Lower Bearing A27537 $3.95 1
21 Magnet A27330 $4.36 1 If using manual controls
59 Brush A27343 $6.17 2
Tools
Tool Note
Bearing separator This is needed for the upper bearing, I modified this one from Amazon
Screwdriver Flat
Screwdriver Torx T-20
Mallet Rubber or wood, something that won’t damage threads
2-pin spanner wrench Good lock ring pliers worked for me
19mm deep socket For the spindle nut above the collet
5/8 or 17mm sparkplug socket For tapping the bearings back on
Needle nose pliers Removing the brush spring
Allen wrench 1/4" Removing top magnet
The Process
Ensure your router is fully unplugged and disengaged from power!
  1. Using the torx t-20, remove the 4 screws from the top cover and the bottom screw underneath the power cord
  2. Remove the top cover
  3. Using needle nose pliers, pull back on the brush spring and move so it is resting with tension on the bar on the right side
  4. Disconnect the LED light wires
  5. Hold down on the spindle lock button, then, using the 19mm socket, remove the spindle nut above the collet that rests on the bottom bearing
  6. Remove the two screws holding the spindle lock in place and remove it (NOTE: watch the spring)
  7. With the router on its side, grasp the outer case firmly with one hand then use a mallet to tap the end of the spindle to disengage it from the lower bearing, the spindle and inner plastic insulator will now slide out
  8. Separate the outer yellow insulator case/magnets from the spindle shaft
  9. With the 1/4" allen wrench, remove the top magnet from the spindle (NOTE: Left Hand/Reverse Threaded!)
  10. Using the bearing separator, remove the top bearing (NOTE: I had to heavily grind down the jaws on the tool I bought to get them to fit, you need a very slim set of jaws to get in there. I tried clamping the bearing in the vise and tapping the end with hammer and brass slug, but just ended up with marred threads. It is really tight on there!)
  11. Position your new bearing on top and using an upside down spark plug socket, tap it into place (NOTE: make sure the socket you use transfers the hits to the inner ring, not the black seals or outer ring)
  12. With the outer aluminum case upside down, attempt to use a spanner wrench or lock ring pliers to remove the black plastic spanner nut holding the lower bearing (NOTE: Left Hand/Reverse Threaded!)
  13. After you’ve stripped through the completely inadequate holes and realized it’s frozen in place, grab your flat blade screwdriver and mallet
  14. Tap the screwdriver into the plastic nut, going away from the threads, when you have enough leverage pry it out
  15. Remove the lower bearing and insert by tapping out from the inside with the handle of your screwdriver
  16. Replace with a new insert and bearing (NOTE: Replacing the insert is not strictly necessary, but it takes a lot of heat and mine was a little brittle - for $2 worth doing now)
  17. Replace the plastic spanner nut to hold the bearing in place (remember, reverse threaded)
  18. Put the spindle back through the lower bearing, it should go on with minimal resistance, but you may need to tap it into place
  19. Install the spindle lock
  20. Holding down the spindle lock, reinstall the 19mm nut
  21. Install the magnet above the top bearing (remember, reverse threaded) (NOTE: A new magnet is not necessary, but if you break it or cross thread it, good to have one on hand. The magnet is only needed if you are using the original manual controls, not needed if you have converted to SuperPID)
  22. Slide the inner yellow insulator back into place, minding the position of the LED wires, reconnect the LED
  23. Remove the old brushes and replace, reposition the springs
  24. Replace the top cover and put back the 4 top screws and 1 screw under the power cord
Photos
I wish I had taken more photos on the way, but this should give you an idea of the critical areas.
Had to grind the jaws down on this to about 1mm to remove the top bearing.
Using a screwdriver to pry out the old plastic spanner nut.
Tapping out the spindle with a mallet
Plastic bearing insert, for $2 replace this piece of plastic
Tapping new bearing into place with 5/8 sparkplug socket (make sure it is hitting the inner steel ring and not the black bearing seals)
Reinstalling the spanner nut with snap ring pliers
Hope this helps someone else rebuild theirs. It goes pretty quick if you have the right tools and parts on hand. The important one is that plastic nut - lots of posts about that being impossible to get off without breaking it. For a few bucks, order all the parts that way you aren’t stuck if something breaks.
I have been lucky and my Dewalt 611 has been running great for 4 years. A couple of months ago the router would not come on and I had a spare set of brushes and replaced them and away it went. I like the Dewalt 611 so much I bought a second one with the plunge kit for trim router use around the shop. I have had a C3d and a Makita and I like the Dewalt better. The newer model machines, mine is an SO3 XXL, use the 66MM router mount although you can by 69MM mounts from C3D. The Dewalt 611 is sometimes in stock at Lowes for $149.00 so rebuilding yours was a good idea.
Yeah, I bought mine as a rebuild unit for $120, so no idea how long it had been used, but it looked brand new when I opened it. This was very subtle. I would not have noticed it If I had not been trying to do some detailed aluminum work. The depth of cut looked random - all within a few thou, but noticeable on the bottom of pockets after bit changes. For some bits, the resistance of the aluminum was pushing the router spindle up a couple thou, for others they would eat down into the material better. My results were passable, but I knew they could be better. Was barely showing up on wood at all, softer materials let the bit naturally sink in more.
Just spun it up tonight and did some surfacing on oak planks from one of my trees.The router is probably half as loud now. My original bearing were screaming! It happened so gradually, I didn’t notice. Now much more bearable and I can tell on the surfacing I did that it is much better compared to some planks I did earlier in the week. Well worth the $20 in parts.
I have some aluminum projects this weekend which, fingers crossed, should really show the difference.
