Diamond drag bits
What do I need to do to use a diamond drag bit on my Shapeoko 3 XXL?. I don’t see the tool in the tool path edit menu in Carbide create I am REALLY new to this
Assuming you’re using a spring loaded drag bit: You want to create a tool that’s about .020" in diameter, when you set up depth of cut, set it very, very small, say .001". When you set Z zero, set it on top of the material you’ll use, and be sure to turn OFF the router. I recommend setting it by hand, not using a probe. You may need to adjust the Z down a few thousandths at a time to get a good “drag” - it takes a little trial and error.
Can anyone tell me what’s the advantage of either 90° or 120° diamond drag bit?
What would u recommend for a step over. This is awesome advise btw. TY
