as requested on support…
Given a file:
and attempting to assign a V carving toolpath to:
The problem is that the geometry has overlapping/redundant lines:
Apparently this image is supposed to be made up of multiple colours:
Selecting the elements which should blend into the background:
We move them to a separate layer anbd temporarily hide them:
It should work now to select the balance of the geometry:
and assign a V carving toolpath with suitable settings:
However, note that these settings must be adjusted based on the Pocket toolpath for this area being at 25mm depth:
