I think I need to clean the controller board. How can I prepare to clean it by discharging any potential in the circuits?
What is your plan for cleaning it? Is there something on it that wouldn’t be adequately cleaned just by doing a good air-blast with it in place?
Or an antistatic brush.
I need to put a filter on my E box because after all this time some humidity or wet particles have begun some corrosion process on some of the pads. You can clean circuit boards that are discharged completely with alcohol.
While you are in there. Make sure the ground is metal to metal
