Although I’ve been in woodworking for a long time, I’m a relative newcomer to the CNC game (< 1yr) and am just getting to the point now where I’m getting reasonable at it. One thing I’m not yet used to is the length of time it takes to do some of these jobs. I can accept the trade off for the accuracy and cleanliness of the cuts, even for jobs that I used to do in minutes with a jig and a handheld router, that might take 20-30 minutes to cut on the CNC…and I readily admit that I don’t have the dexterity to control a handheld router with enough accuracy to provide these kinds of results. However, the thing that drives me crazy is the amount of “Do nothing” time I’m facing.
Everything I’ve read tells you to watch the job as it runs…and be on the ready to hit the kill switch if something goes south. And…being new…I’ve had a number of things go wrong, including having my bit “stick” on retraction out of a pocket that was cut too deep for the cutter - causing my Z to skip and then re-plunge into the work and go straight into the spoilboard. I’ve broken a bit by pushing the speeds and feeds faster than I should have, and I’ve had jobs start in the wrong place because I forgot whether I was referenced lower left or dead center. All my own fault and never to be repeated…but it does leave me with a respect for what can go wrong…and fast. And so, I watch.
Given the combination of my nature and a desire to maximize my time in the shop, I can’t sit and watch something run for 30 minutes, 60 minutes, an hour and half…it drives me stir-crazy - especially when I know I have other things waiting for me in the shop.
What do you do? Do you watch your jobs run? Are you ever-ready at the kill switch? I’m sure confidence will come when I begin to have more and more jobs run without issue (and many do now), but is that a false sense of security? What really is the best practice?
