Does not stop at front on initialization
I powered on my machine after a few weeks of not using it. When I initialize it, the router moves to the back right as normal, but when it comes to the front, it does not stop and continues grinding until I shut it down. I assume there is a limit switch on the front to prevent this, but I can’t find it. How can I ensure that switch is the cause and how to fix?
There are not limit switches. Only homing switches.
What size is your machine? If it’s not a 4x4 I’d try resending machine configuration to make sure it’s setup for the right size.
It’s a 4x4. I went back and set it up as a new machine with 4x4 and still no joy.
Please try the new beta:
https://carbide3d.com/carbidemotion/beta
and re-run the setup wizard:
https://carbide3d.com/hub/docs/shapeoko-setup/
If things still don’t work, let us know at support@carbide3d.com and we’ll look into this with you.
