I’m trying to migrate to this software and i can’t work out how to use mm units in the program. my bit is 1.5mm in diameter and it says that is NaN.
It also happens in the main menu, it doest’n accept the decimal point or the comma.
Hi Pedro,
most likely the same internationalization issue I had : see Values showing up as red and cannot type dot character?
The fix is to change the decimal separator. In the Windows Control Panel, open Regional and Language Options
, under the Format
tab click Additional Settings
, and changeDecimal Symbol
from “,” to “.”
Thanks a lot! that did the trick!
Hello Julien.
Thank you that solved the problem. With the mm / inch.
Much apriciated.
Brgds. Ove
