I want to engrave 4 circles but when I create my toolpads I only get dots and no circles. What am I doing wrong here?
V carving only cuts at the center of the geometry, and can only cut as wide as the endmill geometry will allow.
I believe you’ll get the result you want with an Advanced V carving toolpath which cuts around the perimeter:
Yep, that did the trick, thanks! (learning every day here…)
You can just do a ‘Contour’ cut, with no offset.
Doing an ‘Advanced Vcarve’ with no clearing bit seems equivalent to a ‘Contour’ cut with ‘Inside’ offset.
Two same size circles, top is Advanced VCarve, bottom is Contour no offset.
Thanks Michael, that worked!
