Downcut endmills
Should you run a downcut endmill at the same feeds and speeds as an otherwise identical upcut endmill?
In theory, yes.
It may be thought that chip clearing will be a problem which will require either reducing depth per pass, or feed — recutting chips can be a problem w/ them.
