I have been digging around this site, the wiki and the interwebs about drag knives. While I found a nice design to print tomorrow for the actual knife, I am lost as to what software to use.
Can Carbide Create along with the excel spreadsheet from Donek create the right GCode? What packages do others use? Has anyone used Fusion 360 for this?
If a design will accommodate rounding all of the corners, one can cut it without the need for special cornering action moves. Without them, any CAM software should give you a workable result with a Drag Knife. Simply use an engraving style (follow) toolpath which follows the line in your design which you would wish to have cut.[28]
