I am getting a drag knife for my shapeoko pro to cut rubber (2.8MM) and vinyl. Was wondering if someone could advise me on speeds and feed?
Perhaps the feeds and speeds which we use for the Stingray will be a useful starting point?
Well, speed should be zero. Feed is what you want to set and you should do some experimenting with your material to see what works. I would start sorta low, like 35ipm or so and see how it goes.
