I’m using Fritzing to generate a Gerber file for an incredibly simple parallel circuit test. As far as I can tell, the .txt drill file is exporting all the holes and they are all showing when I import the file into Carbide Copper. When I generate the gcode however, only half the holes show up. I tried building a new circuit from scratch just in case it was something I did in Fritzing, but the same thing happened. I can’t find any documentation on how to solve this problem. Does anyone have a reliable sample circuit they can share so that I can test?
The holes that do show up, are they in the correct positions?
Can you post/send a copy of the Gerber you have generated from Fritzing?
