I have the Dewalt router and when loosening the collet it takes both hands. At a point the bit falls out of the router. My table over hangs the bed by about 4.5 inches so the bit would hit the wooden top but sometimes rolled off on the floor, oops. I went into a discount store and found these plastic containers (3) for $5.00. They have a slight pad in the bottom and keeps the bits from rolling off the table. FYI
It would be really good if you could set the tool-change position in CM.
It would also help the Raspberry Pi compatibility.
This was my solution - posted in a similar thread:
