I want to add a manual jog wheel for the Z axis of my Shapeoko which is equipped with an HDZ. The number of times I have had to raise / lower Z with the machine powered off is not zero and every time it is annoying to do so. In order to add a job wheel I need to swap the stepper motor for a Dual Shaft version. I am thinking of getting this guy:
and was curious what others think of the idea? It is a bit beefier than the stock stepper from what I can tell.
Honestly it is a first world problem of my own creation. Most of the time I have run into this is when modding the machine or doing maintenance. As such it requires turning on / potentially the control board as well as the PC controlling it. All to move Z down a centimeter.
My solution to that problem would probably be to hook up a separate Z-only control board with its own power supply and stepper driver but at that point I think just putting a handwheel on a second shaft is a better idea…
