Dumbfounded/laser/Lightburn
If you look at the pic you see the bottom 3 are fine.The top 3 are messed up just above the eye of Jesus. I initialy had 9 in a batch but forgot to put my machine in laser mode. so i just selected 6. Anyway,Ive repeatedly, 3 times at the same spot my machine makes a grinding noise and jump off to the left. I did have some open vectors that i ignored and thought that might be the problem. I did get rid of them and tried again. Same thing. Now if i dont add the pic of Jesus in it it runs fine.I’m running it at 8000mm Is that pushing it too much you think?
Can you share ypur setup?
I’m guessing your preview in LB doesn’t show any flaws?
Have you tried to just make one emblem on the top row?
I slowed down the speed to 6000 and had a successful run seems I was going to fast.
