Dust Collection Turn on when Spindle Turns on
I’ve seen some examples of a gadget from Amazon where you turn on the router an the dust collection also starts up. I have the 80mm spindle with the 220 plug. Has anyone put together a setup that would work with that?
See:
https://carbide3d.com/hub/faq/controlling-a-vacuum-with-your-shapeoko/
ivac has a higher voltage variation iVAC Pro Switch, 240Vac, 20A – shop.ivacswitch.com as well as a current sensor that might work
Does the 80mm spindle really take 220 or is that just the VFD?
The 80mm VFD spindle has a VFD which uses an
L6-20P plug
for a 220V outlet.
There is an additional plug for the chiller which needs household/residential current:
110V outlet for the water chiller
