For those with an enclosure with the dust collection hose running thru the top, how much clearance is needed to provide ample room for the movement of the spindle. At a future date I may upgrade to the pro and 2.2 spindle. I upgraded to the Sweep 2.0 which has provided me with the opportunity to revamp my original top enclosure which was not tall enough. I need to lengthen the top as well as raise it. Want this to be the only time I have to do this. I will be using 2" flex hose which I want to route thru the top. Will some sort of swing arm aide in the movement?
Steve
I don’t don’t have the dimensions off hand but I utilized a 1.75" flexible hose with a swivel connection. This allows more than enough flex without binding.
Darren,
Would like to compliment everything about your enclosure. The lighting is fantastic. Had not thought about running the inlet side of the dust collection to the front. Thinking I will do the same setup.
Thanks for the reply.
