Is there an article somewhere explaining how to use dynamic values in CC V-7 tool path setup. Or any other places.
It’s just math.
- (NEW) Expression evaluator in dimension entry boxes. Hit “=” after the expression to calculate.
- (NEW) Expression evaluator can reference bottom of stock as variable “t”.
If you are using the dynamic option, just enter a math formula which describes the desired result:
want to cut halfway through the stock?
t/2 -
want to leave a 1/64" onion-skin?
t - 0.015625in
&c.
at:
I note:
Note that in Carbide Create, dimensions may be entered using math expressions (which may contain units indicated by in or mm) which are evaluated by entering = at the end, so 1in+8mm= will result in a dimension of either 1.3150in or 33.400mm depending on the current unit. The variable t may be used to reference the current stock thickness, and the expression may be left as an expression by entering it without adding the = at the end, so t/2 will result in half the current stock thickness being used, and will update dynamically when the stock thickness is changed.
Is more necessary?
I thought about giving the example that you can mix and match units, but that seemed kind of contrived.
I didn’t know “t” was a thing. Are there other parameters that exist or can be defined?
At this time, only t for stock thickness.
