I am attempting to place multiple lines of text on a small plaque. Cant find an easy way.
I converted document to SVG, but will not load text.
Any help is greatly appreciated. I am very new to this machine and hoping to find an easier way.
Thanks!
If you have the text set in an SVG the easiest way to get it into Carbide Create is to convert it to paths — in Inkscape the command for this is Path | Object to Path (save a copy where the text is still text if you wish to be able to edit it).
In Carbide Create you would have to set the text one line at a time, but you can get multiple lines which are evenly spaced by using the Linear Array tool:
