Easy Feeds and Speeds
hahah
you’ll just need to work top down.
  1. Select the Material you plan to cut.
  2. setup or select your machine profile. (My machine profiles are public)
  3. select your end mill
  4. select your depth of cut
  5. select your width of cut
  6. adjust the sliders to your comfort level. (I used 100% on speeds and chipload and around 50% on performance)
    Speeds and feeds are updated in the upper right corner of the screen.
    use them in your F360 toolpath DOC, Stepover, Engagement fields.
    easy! :wink:
