In the latest build I am unable to find the “edit tab” button. Please assist.
TIA
TIA
As noted at:
We added a new tab command to add tabs to a vector. If you copy the vector, you copy the tabs too. This should be helpful for users that are doing production work where they may want to fine-tune the machining of a single item and then copy and paste an array of them for full production.
Look for the new command here:
