I just received my EMI kit from carbide 3D today. Does anybody have instructions on how to use the parts? It can with a usb isolator, a grounding Wire that plugs into an outlet and has a alligator clamp on the other end, and a power cord with some metal box on the wire.
I do not have the kit, but I’m guessing;
The USB isolator goes in-between your PC and CNC.
The wire with the alligator clip is for grounding the CNC/ router.
The power cable with box on it I’m guessing is a line filter for your router.
support@carbide3d.com should sort it out promptly.
