Downloaded CC B530 today, made a basic pocket tool path to resurface my machine (SOPROXXL) to .05 in. depth and 30in. x 30in. on XY respectively. One thing is that the simulation feature doesnt work, and second, after saving the Gcode the file size is just 1kB?
this is what the G code looks like after saving it…
while running the code it just prompts me to change tool, then to start the Spindle, then it goes to the zero XY and nothing else happens… any idea?
This is exactly what happens here quite a lot. After that the machine goes back (very slowly) to the homing position before you can do anything else. Frustrating. This in combination with the crash when using the simulate option I have decided to wait for the next updated version…
Yes, exactly that (reproduced it on my machine). Just setting max depth to 0.0501 for the sake of testing produces the right gcode.
It seems to be a corner case where CC should rather not display at toolpath at all and produce an error, I can see how this is misleading.
However I don’t get while you would want to set start depth = max depth anyway ?
I you need to shave off 0.05", set start depth at 0 and max depth at 0.05", and zero off the wasteboard ?
